cadffm
en respuesta a: jay
What you see is the real Textstring of your Mtext.. (select the MText and check the properties..)
Simple solution1: Don't use the internal formattings in your Mtext, problem solved.
(use TEXT instead of MText, or create a new MText and don't add internal formats)
Solution2: Create your own fieldcode - not all working properties are offered by Field-Dialog!
Create a field (you did), copy the fieldcode (edit the field or create a new on, while in dialog you can copy the copy [ctrl+c]
Edit the code from %<\AcObjProp Object(%<\_ObjId nnnnnnnnnn>%).TextString>%
to
%<\AcObjProp Object(%<\_ObjId nnnnnnnnnn>%).Text>%
copy the line above and paste it wherever you want [ctrl+v]
Sebastian
