- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
>>>>>Another issue is when I zoom in to select an object to copy and then zoom out so I can past it somewhere else the zoom will only partly zoom out and not enough to work so I have to paste it and then move the object where I want it.
Looks like you zoom too deep into the drawing area. AutoCAD has to regenerate drawing when you zoom out at some point, that is why you cannot continue with COPY command - AutoCAD needs to REGEN, but it can't because COPY command is active.
If you need to copy something in such situation, you can temporary create two viewports: one for "deep" area, another with area where you want to copy the object. Switching viewports doesn't require regeneration during COPY command.
Another way - use clipboard - COPYBASE and PASTE commands.
Maxim Kanaev
Architect
MARSS
