jamesPDEAU
358 Vistas, 4 Respuestas
Bug: Project Manager does nothing when I try to add existing drawings
Hi there, so I've hundreds of separate dwg files and would like to use project manager to organise them. There seems to be a bug however that means I just cannot add any existing drawings. This seems to have been an issue before because there's a troubleshoot page for it: https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle...
However, I've just checked and the file type is indeed associated with AutoCAD LT for Mac, the version I'm using. Would there be anything else I could try or that may be going wrong?
Software: AutoCAD LT for Mac 2021 (latest update)
Hardware:
Model Name: iMac
  Model Identifier: iMac18,3
  Processor Name: Quad-Core Intel Core i5
  Processor Speed: 3.4 GHz
  Number of Processors: 1
  Total Number of Cores: 4
  L2 Cache (per Core): 256 KB
  L3 Cache: 6 MB
  Memory: 24 GB
  System Firmware Version: 447.80.3.0.0 (Monterey 12.2)
pendean
en respuesta a: jamesPDEAU
LT is what exact year version?
MacOS exact version is...?
jamesPDEAU
en respuesta a: pendean
Sorry, LT 2021, Monterey 12.2. Updated in the question above too
jamesPDEAU
And to add to the question, when I try to add a drawing nothing will happen but it will say 'Last updated' with the current time.
I can create a new drawing no problem, but that obviously does help when you've hundreds of existing drawings
maxim_k
Hi @jamesPDEAU ,
Have you installed 2021.2 Update to AutoCAD LT 2021 which fixes compatibility issues with macOS 12 Monterey?
Where are the drawings you are trying to add to the project located? On local drive? On network drive?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
