meryembursali
576 Vistas, 4 Respuestas
Attributes text going out of the block box
Hello!
I use AutocadLT for Mac. I created a block with multiple attributes, its a block with the room finishings informations.
When I change one of the attributes, if the text is longer, it doesn't stay inside my box !! How can I fix it? I attach a screenshot.
Thank you!
maxim_k
en respuesta a: meryembursali
Welcome to Autodesk Forums!
Hi Mery!
@meryembursali
I think you can try to edit the block and set justification for the attribute definition in question to "Right" and move the insertion point of the it closer to the right side of the box:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
To update existing block insertions use ATTSYNC command.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
meryembursali
en respuesta a: maxim_k
Hi Maxim!
Thank you! I have tried to change the text alignment justification after i did the block, from att. editor itself but it wasn't working!
But now I changed it before creating the block and it does work. Thank you again!
maxim_k
Hi Mery,
As I wrote here, you need to update existing block insertions use ATTSYNC command.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
