inaki.susbielles
254 Vistas, 1 Respuesta
can't use shortcuts
Hello,I've installed Autocad LT for Mac and I'm having issues with shortcuts. They are not set up so I have to write every command. I've made some research and when I try in Edit command Aliases the program crashes. Hope you can help me with a solution soon. Thanks
Etiquetas (1)
maxim_k
en respuesta a: inaki.susbielles
Hi @inaki.susbielles ,
Please specify AutoCAD LT for Mac version you installed and macOS version installed on your Mac.
What do you mean by shortcuts? Can you provide some samples?
Make screenshots of Command window with AutoCAD response to shortcuts you tried to use.
How do you edit command aliases? Please describe in more details.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
