sehyun0701
283 Vistas, 1 Respuesta
Different Blocks Palette
Block Library is shown differently on autocad.
This one is AutoCAD LT 2021 for MAC.
This one is AutoCAD LT 2022 for MAC. I want this to pop up on the upper computer so I can bring blocks on other drawings.
They're on different computers.  Not sure if it's version difference or some other issue.
Pls help.
Thank you
maxim_k
en respuesta a: sehyun0701
Hi @sehyun0701 ,
In version 2022, the blocks palette has been changed.
In if you want to use blocks from drawings in 2021 version you need to use "Manage library..." item in Blocks library dropdown to create your own block libraries:
https://help.autodesk.com/view/ACDMAC/2021/ENU/?guid=GUID-350F4101-6108-4AA8-810B-376442622901
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
