japanpersonals
en respuesta a: maxim_k
>No one forces you to use annotative dimension and text styles, you can still work in AutoCAD without using them ...
No-one forces you walking on two feet. You can still jump on one foot, or creep on the ground.
I just installed a new Autocad LT, and found to my surprise, that scale boxes disappeared in the bottom-right toolbar. The annotation scale is also cannot be changed in the Paper view with cannoscale, or even within the properties of the anno.object; even though I added the "1:5" scale in the list.
The roll-out configuration is broken
The UI is broken
The scaling mechanism is broken
The manuals are absent, or do not answer the question
Autodesk, what the hell is going on!?
