- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have a CAD file that I would like to export in EPS and the LT for MAC 2020 program seems to only allow for PDF export.
Is there something I can do to export the image in EPS?
Thanks!
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @hanerZY6L7 ,
Save your drawing as PDF in AutoCAD.
Open PDF in Preview app, use menu File -> Print to open Print window.
Open PDF dropdown list and select "Save as PostScript":
You will get .PS file.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I have tried printing from Preview, but the file size is quite small. My assumption is that creating an EPS directly from CAD will create the best quality image, in this case for publication.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Greetings @paul8TSZ5
You'll need to find a 3rd party solution (or website) that can do conversions for you if the tools explained above are not what you seek for quality output (file size is not a good gauge of that BTW).
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Is this related to printing from model space or the fact that this is a trial version or a mac version?
Paul
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Paul,
@paul8TSZ5 wrote:
.....The Autodesk help sites suggest I should be able to add EPS as an option when setting up the plotter, but no wizard exists and I don’t see a way to manage plotters.
This information is about AutoCAD for PC. On Mac you can only add macOS System printers/plotters, but not in AutoCAD.
BTW, I tried to print from AutoCAD to PDF file and then save it as Post Script from standard macOS Print window and got quite acceptable result - PostScript file with vector data.
Maxim Kanaev
Architect
MARSS
