- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Recently updated to 2022 font (Heiti SC reg) displaying on sheet but not displaying properly in pdf created using DWg to PDF.PC3
Hi!
I and others in our practice have recently updated to 2022. We use the font Heiti SC regular. This displays when in autocad but once PDFed using dwg to pdf. pc3 the text errors as in the below screenshot. The font is correctly installed on the system, it has been replaced, to check it is not corrupt, this had no impact. Solution welcome?! tried allsorts and had no luck so far. I am on Mac OS Monterey 12.2
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @lauraQH6G3 ,
Try tu use "Convert all text to geometry"
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks Maxim, that is what I have been doing as a temporary fix. Will continue to do this until I there is a full solution.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Laura,
>>>>Heiti SC regular
Is it commercial font?
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
As a test only, does the visual aspect of those fonts improve if you select this option?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
>>>>Standard Mac Font which comes on the system
Then I will check it on my side.
What macOS version do you have on your Mac?
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I cannot reproduce this issue on macOS BigSur 11.6.3
Have you installed >>>this<<< Update?
Can you share your drawing here?
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
A portion of your DWG with that same text in it would be nice too, if you can.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi, this update will not work as I have autocad LT, is there a LT version of the update?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Please see files attached
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Sorry it was my fault.
But now I see that you have all the updates installed.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @lauraQH6G3 ,
I tried to save PDF form your drawing and all text looks correct (see attached PDF).
As I wrote before, I have macOS Big Sur on my Mac, maybe the case of incorrect font representation is macOS Monterey, but I'm not sure.
Please post screenshot of Print window at the moment when you save drawing to PDF.
Maxim Kanaev
Architect
MARSS
