sehyun0701
376 Vistas, 5 Respuestas
Annotative blocks on an XRefed file only shows when Annotation scale is set to underscored scale
Hi all, I'm using AutoCAD LT for Mac and there's some issue with Xref/Annotation scaling.
I drew some annotative objects(blocks/texts/dimensions/etc) with annotative scaling property of 1:100, 1:150 on file 'A'.
Then I XRefed 'A' into 'B'.
I also drew some annotative objects with 1:100, 1:150 on file B.
In file B, when I set the file's drawing scale to '1:100', it only shows objects drawn on B and the objects in A disappears.
There's a scale named '1:100_XREF' and when I set that as the drawing scale it only shows objects in A and not in B.
When I set the scale to '1:150', it shows all the objects with '1:150' property, both on A, and B, which is what I want with 1:100.
Shouldn't the objects in A also show when I just set the scale to '1:100'?
pls help.
Also, ANNOALLVISIBLE is not the solution I want.
I can't delete scales with '_XREF' in the name.
scales with '_XREF' in the name imports into B even when there is already same scale existing in the scale list.
Etiquetas (1)
