- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
WHEN ZOOMING IN/OUT LINEWEIGHT IS NOT VISIBLE ALL LINES ARE THE SAME
Hallo,
I work with visible Lineweight .When I zoom in/out all the lines become thin and when I leave the zoom command the lines appear with their Lineweight , wich is very annoying and I can't work, is there any possible solution ,,,,?
I am on macOS Monterey 12.0.1
3,1 GHz 6-Core Intel Core i5
8 GB 2667 MHz DDR4
AMD Radeon Pro 5300 4 GB
running Autocad 2019
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Welcome to Autodesk Forums!
This is standard behaviour in AutoCAD for Mac.
There is no workaround other than turning off lineweight visibility.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Ups....! that's a small disaster... In case I make partition with windows in my Mac and I run Autocad from windows ,would I have the same problem...?
Thanks!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Display Lineweights
1) Lineweights can be turned on and off in a drawing, and are displayed differently in model space than in a paper space layout.
2) In model space, a lineweight of 0 is displayed as one pixel wide, and other lineweights use a proportional pixel width. Lineweight display in model space does not change with the zoom factor. For example, a lineweight value that is represented by a width of four pixels is always displayed using four pixels regardless of how far you zoom in.
3) In a paper space layout, lineweights are displayed using real-world units, and lineweight display changes with the zoom factor.
4) By default, lineweights are plotted with the exact width of the assigned lineweight value.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
No, you wouldn't have this problem.
In AutoCAD for Windows in Model, you will not see switching of lineweight visibility during zooming with mouse wheel.
Maxim Kanaev
Architect
MARSS
