michaelsirolli
686 Vistas, 6 Respuestas
grid is invisible.
I am a student and i have tried to make my grid visible and am unable. If i change the color of my modelspace to white, the grid is visible. It is a class requirement to turn every assignment in with a black modelspace. I find myself working in white and changing it to submit. is there any way i can make the grid lines white?
michaelsirolli
en respuesta a: michaelsirolli
more screenshots of settings
maxim_k
Welcome to Autodesk Forums!
Hi @michaelsirolli ,
If you have full (not LT) AutoCAD for Mac version, you can use these AutoLISP expressions to set grid lines color to white:
(setenv "2D Model grid axis lines color" "16777215")
(setenv "2D Model grid major lines color" "16777215")
(setenv "2D Model grid minor lines color" "16777215")
Copy - paste these lines to AutoCAD command prompt and hit Return.
Use REGENALL command to see the effect
To restore default colours use these AutoLISP expressions:
(setenv "2D Model grid axis lines color" "6114631")
(setenv "2D Model grid major lines color" "6901577")
(setenv "2D Model grid minor lines color" "4732722")
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
michaelsirolli
en respuesta a: maxim_k
I don’t understand how to enter these
maxim_k
@michaelsirolli
Select the code I posted, copy it to clipboard (Command +C), return to AutoCAD, put cursor to Command window, paste from clipboard (Command +V).
Hit Return key.
Use REGENALL command.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
michaelsirolli
this does not work. does it matter that it is a mac. i tried this after seeing you post it on another forum for windows. i just tried it 3 times tonight.
this is what i pasted in command line
michaelsirolli
my apologies. I quit and relaunched autocad and now it worked. the grid is white. thank you very much. My professor was even unable to help with this problem
