josemariaportela
2890 Vistas, 12 Respuestas
problems Mac OS Monterey
Autocad can“t open all dwg working under Monterey OS... I don't now why... some of them yes, y another no... in this case, AutoCAD don't work and must exit.. if I try to open by windows Autocad, there is no problem...
The file can be very big, and work, or small and don't open it...
pendean
en respuesta a: josemariaportela
Share one or more of those DWG files here please, and post screenshot whatever error message AutoCAD's OPEN command states, and a screenshot of where you store/keep those files.
adminVQTXV
What do you mean with "  if I try to open by windows Autocad, there is no problem.."
Like opening windows bootcamp on mac?
I mean it is not a problem of the file... the same file works ok under Autocad Win64...
Sometimes, can't open Autocad... I Think is a problem of Os Monterey...
maxim_k
Hi @josemariaportela ,
What AutoCAD for Mac version are you using?
Can you share one of the drawings which caused AutoCAD for Mac to quit crash you are trying to open it?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
josemariaportela
en respuesta a: maxim_k
versión 2019, 2021 an 2022... it happens in all o them... Mi computer, Mac mini I7, 16gb RAM; last Wednesday I“ll try to clean a file to send to you, and them, it works... but today don't work... I think is a problem with OS
josemariaportela
do not crash... don't open.. sometimes don't open AutoCAD
I tried re install AutoCad, bar it is the same...
maxim_k
Have you installed latest Update for AutoCAD that fixes compatibility issues with macOS Monterey?
For example for AutoCAD 2022 for Mac, the Update is here:
https://knowledge.autodesk.com/support/autocad-for-mac/downloads/caas/downloads/content/autocad-for-...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
josemariaportela
Is already install...
Perhaps something goes wrong installing os Monterey...
maxim_k
Let's try to clarify the problem again.
Can't you launch the app (sometimes)?
Or are you unable to open some drawings (sometimes)?
If the latter - Can you share the problematic file that does not open in AutoCAD?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
josemariaportela
sometimes the app do not open... then, I need to restart app or restart Mac...
and, if the app is open, some files do not open, without wrong message... in this moment, the app can't work a I need to restar it again
it happens with 2019, 2021 y 2022 versions
How may I share one of those files..?
maxim_k
You can attach DWG file to your post here.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
josemariaportela
I found the problem is if there is a image raster in a Layer not freeze... If I freeze it, I can open the file
