g.o.eley
467 Vistas, 3 Respuestas
There are thick lines surrounding the buildings, how do I get rid of these please?
I am a student and fairly new to AutoCAD, I have been stuck on this issue the last two days and would be really grateful for some help. I am trying to make an isometric view of a map I can put into photoshop for part of my site analysis, the map and building heights are imported from CADMapper. All the building have a thick outline around them and I can't work out why or how to remove it. Alternatively I can put it into '2D wireframe' but then you can see all the geometry which I also don't want want! I am working on a MacBook Pro, I have attached both screenshots and my file. Please can somebody explain how I can resolve this,
Thanks in advance,
Grace Screenshot 2021-12-30 at 17.39.22.png269877722_3299726970250316_4093930310369191236_n.png270145006_464727301735175_5599820785939730212_n.png269932451_1575943096095415_7069035230377880790_n.png
Etiquetas (1)
ennujozlagam
en respuesta a: g.o.eley
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Unable...
maxim_k
Welcome to Autodesk Forums!
Hi Grace,
@g.o.eley
You need to adjust settings for the current visual style -
change System Variable VSSILHEDGES to 0 (zero) and try to create PDF.
At the command prompt type VSSILHEDGES and hit Return:
Command: VSSILHEDGES
Enter new value for VSSILHEDGES <1>: 0
Command:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
g.o.eley
en respuesta a: maxim_k
Thanks so much this worked!!!
