- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Welcome to Autodesk Forums!
Hi Scott.
>>>>>The problem we are running into is that in windows when an attribute was hidden in a
>>>>>visibility state it was also hidden in the properties explorer, now on Mac they all show
>>>>>up regardless of visibility. Is there a setting I need to change to fix this?
Looks like it is a bug (defect) in AutoCAD for Mac.
>>>>>when we are using the dynamic block to set everything up we like to hit enter to tab through all the
>>>>>attributes because it will just take us to the next one down, but on Mac when I do that it just deselects the attribute.
It is known behavior in AutoCAD for Mac and it seems to be OS dependent feature. You can try to move between input fields in the Properties palette by hitting Return after you change field and then using up/down arrows to go to the next field, hitting Return again will activate field for editing.
Maxim Kanaev
Architect
MARSS
