maxim_k
en respuesta a: PBJE
Hi Peter,
@PBJE wrote:
I thought it was a system variable and it was.
Not "Show object transparency" but "Transparencydisplay".
On the system running Big Sur it was (0) and on the system running Monterey it was (1)
They now both are (0) and look like things are identical again.
There is a button on the Status Bar:
which toggles TRANSPARENCYDISPLAY Sys Var, you might accidentally switch it.
@PBJE wrote:
The other strange thing is that I do not receive automatic updated for AutoCad anymore for both systems.
Also when I click "Check for updates" nothing happens.
I need to do this manually.
Please check if you have enabled notifications for AutoCAD in the Notifications pane of macOS System preferences.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
