393 Vistas, 2 Respuestas
X-ref Imperial scale drawing (inches) within Metric Scale drawing (millimetre)
I work with metric scale (drawn in millimetres) but I am working with consultants who are working in imperial scale (drawn in inches).
It's easier for me to think in metric scale, so I would like to x-ref the consultant's drawing (imperial scale) to my template (metric scale) so I can draw in metric scale with an accurate base drawing.
Can you please advise if this is possible?
Thank you.
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi @Anonymous ,
For the Xref to scale automatically during attaching it, you need to set system variable INSUNITS in both drawings (Metric and Imperial) correctly.
In Imperial drawing INSUNITS should be 1 and in Metric drawing it should be 4.
In this case the contents of Imperial drawing will be scaled correctly when you insert it as Xref into the Metric drawing.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
@maxim_k
Thank you very much maxim - this works!
I really appreciate your help.
