maxim_k
en respuesta a: Anonymous
Hi @Anonymous ,
>>>>>But I need to know how to get the auto populate sections right so they take the information from the drawing
When you create title block, you use ATTDEF command to create attribute definitions with contextual fields as default values:
https://help.autodesk.com/view/ACDMAC/2022/ENU/?guid=GUID-5606204E-DBAC-4BC5-BB01-F7F1BABA0620
https://help.autodesk.com/view/ACDMAC/2022/ENU/?guid=GUID-742C92C3-1284-4722-B650-C46F9191C701
https://help.autodesk.com/view/ACDMAC/2022/ENU/?guid=GUID-1B6DD22B-10D1-44ED-BAA2-E6D79FE52327
>>>>>how do I load my title block layout into another drawing
After you create title block in a separate drawing, you can add it to any of your drawings with several ways:
- use Copy - Paste
- use Blocks Palette to insert title block from that drawing
- add Title block to your custom template.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
