ericAvB
en respuesta a: ginacerv
Hi @ginacerv,
Some quick questions:
- Have you also checked the transparency properties of each item specifically? Because you can edit transparency properties individually (set it to by block, by layer or by object). This can interfere with the adjustments you make in Layer Properties;
- Are these items blocks?
- If so, make sure that the entities in the block are placed in layer 0 with transparency properties set to ByLayer;
