maxim_k
en respuesta a: Anonymous
Hi @Anonymous ,
1/
 From the attached PDF I see that the non-bold font is PostScript Type 1 font, but not TTF font:
I think this might be a problem. PDF engine cannot create correct representation of PS Type 1 font, when you "print" from AutoCAD.
BTW, have you seen >>>>this<<<<?
2/
>>>>The unconverted one prints differently than designed, and more importantly causes the PDFs produced in either "plot" or "publish" to be unreadable, like the PDF will not even open
What printer you are using in Page Setup, when you are trying to save PDF from Print window? Do you use the same printer, when you pick on Preview button in Print window?
I tried to recreate your drawing using Obviously TTF fonts I generated from Obviously Variable TTF font:
 and everything seems fine in PDF output (see attached).
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
