bret_wieseler
1658 Vistas, 2 Respuestas
MTEXT automatically adding dynamic columns
Can someone tell me why when I create text using the MTEXT command, dynamic columns are automatically added to the text?  It's extremely frustrating and inefficient to set remove the columns from the text.
Thanks.
iMac | 3.6 GHz 8-Core Intel Core i9 | 64 GB | Ventura 13.6.6 | Autocad LT for Mac - 2024.1.2
Etiquetas (2)
pendean
en respuesta a: bret_wieseler
Look up MTEXTCOLUMN (System Variable) and keep track of the setting you don't want when you don't want it (you automate that latter with SYSVARMONITOR command, also explained in HELP if the MAC version has that).
maxim_k
Hi Bret,
SYSVARMONITOR command is not available on Mac, but look at the MTEXTCOLUMN System variable and set it to 0 (zero) as @pendean suggested.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
