en respuesta a: maxim_k
Hi @maxim_k
Thank you for your reply,
I've seen both of your posts in other topics but neither solution is ideal... I tried using Acrobat reader to save PDF's (same issue occurred) and I can't really ask every client to print JPEG images every-time I send a drawing... these are small drawings and I send a lot of them daily...
So while JPEG is a workaround it's not a solution in my opinion (thats what I've been doing so far since the issue happened again)
I guess, I find it hard to accept that every user of AutoCAD for mac has the same issue and is ok with it... because if thats not the case what setting do I need to change to not have that problem?
Also I thought that there might have been an update on the issue since last year :cara_que_sonríe_con_ojos_sonrientes:
