- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @pendean
Thank you for your reply,
Answers to your question below:
1. yes thats correct, it seems to be these 3 in this drawing. Every drawing has a different issue... Sometimes it catches larger gradient and nearly whole page turns black.
2. PDF - I select my physical printer (HP Photosmart 5524) and use "Save as PDF" button. I used in the past preview and save as, as well as plotted to Autocad PDF printer. Same result every-time.
PHYSICAL PRINTER - mine is as above but the same issue comes up on other, various printers too
3. Yes product is up to date.
4. I am using Mac ''preview'' but again my clients use most likely Adobe Acrobat reader.
5. Standard coloured settings, didn't make any special adjustments. Not using B&W or eco setting.
