4799 Vistas, 6 Respuestas
M1 Autocad under Rosetta 2
will autocad run smoothly on macbook air m1 2020 under rosetta 2? and how long it took to render on macbook air m1 2020 under rosetta 2(just estimation)?
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi @Anonymous ,
Yes, AutoCAD 2020, 2021 and 2022 for Mac run smoothly on Macs with M1 chip under Rosetta 2 mode
If I understand your question correctly - AutoCAD for Mac doesn't include Rendering engine, you can use Autodesk online Rendering instead.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Does AutoCAD come in an M1 ready version or must it run thru Rossetta 2
pendean
>>....Does AutoCAD come in an M1 ready version...<<<
If there was one you'd have it already: future versions will likely add this ability, why not join the Beta program at Autodesk and find out for sure https://feedback.autodesk.com/welcome/
maxim_k
Hi @Anonymous,
For the moment - only under Rosetta 2
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
mcather
I just downloaded autocadLT 2023 for Mac on to my MacBook Air M1 2020...and did Not get a message to install Rosetta? Do I not need it?
maxim_k
en respuesta a: mcather
Hi @mcather ,
You could get an alert about Rosetta only on first AutoCAD launch.
If you already installed and launched it without this alert, then Rosetta 2 is already installed on your Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
