PaulMarsh8527
294 Vistas, 2 Respuestas
Multileader multiple leaders ads extra line weight
Hi
I am using AutoCAD LT on the latest Mac mini and am having a problem with the leader line weight incrementally increasing as multiple leaders are added to to the multileader when all leaders are in the same plane.
I would like to see if it would be possible to only show a single leader line at 0.09 only.
Any assistance would be greatly appreciated.
screen shot multileaderscreen shot multileader
screen shot for example, Line weight is shown as 0.09, line weight on. Fine next to the leader but thickens at the offset point and decreases thickness as each leader landing point drops off!
Regards Paul
maxim_k
en respuesta a: PaulMarsh8527
Hi Paul,
It is just on-screen visual effect.
In fact line thickness does not change in the area where the leader lines overlap. You can check this by saving your drawing to PDF format.
And I think it is impossible to remove this on-screen visual effect.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
PaulMarsh8527
en respuesta a: maxim_k
Thanks there Maxim_K your dead right on the PDF print.
Cheers Paul
