06-30-2021
07:31 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-30-2021
07:31 AM
Hi Maxim,
I run to the same problem state above...the block editor just open up automatically when I click on a random block that I created. No no attribute on it. Its very annoying to always close the block editor and waste of time. The only solution I found to correct partially this problem is to change the variable of " BLOCKEDITLOCK to 1" but with that...it also mean if i need to edit a block I need to change the variable back to '0" ....any other solution you help me with? any variable i should be changing???
FYI Im using autocad Lt 2021 Mac... this problem never occur to me before....
Thks in advance!!
Thks in advance!!
