199 Vistas, 1 Respuesta
06-15-2021
01:05 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-15-2021
01:05 PM
Quickcalc
I am using AutoCad 2020 for Mac and I am unable to use Quickcals. help asap
When I type it in the command bar it doesn't come up. It is not under tools either.
However when I want to create a new panel and I look for it there it its, but it appear.
HELP ASAP PLZ
06-15-2021
02:02 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
06-15-2021
02:02 PM
"QUICKCALC is not available in AutoCAD for Mac.
Inside AutoCAD for Mac you can use only command line version calculator - CAL:
https://help.autodesk.com/view/ACDMAC/2020/ENU/index.html?guid=GUID-335A5FC6-7D8F-47CA-B479-26655CDE...
You can use this command transparently inside another command for calculations by adding ' before the command name:
'CAL
If you have full AutoCAD, you can also use AutoLISP expressions for calculations."
'CAL
