kevinHGNEU
874 Vistas, 2 Respuestas
Adding a logo to AutoCAD 2022
Hello all,
I am trying to add a logo to my tittle block on AutoCAD.
The original file is an illustrator file, which I exported as a DWG File and inserted into my drawing in AutoCAD.
The problem I am facing is when I plot the drawing into PDF the text prints disrupted on the logo, and I am not sure how to fix it. I tried by using the option "Make Pixel Perfect" on Illustrator and then export as DWG, but unfortunately it didn't make any difference.
Please see the screenshot attached of the disrupted logo.
Thank you very much in advance for your help.
Best
Vanesa
Etiquetas (3)
pendean
en respuesta a: kevinHGNEU
Plot parameters?
Which part of your screenshot is the logo?
Where is your DWG source file with the exported Illustrator content?
And where is the PDF?
maxim_k
Hi @kevinHGNEU ,
Look at the attached DWG and PDF created from it.
Is it what you need?
If yes, then you need to erase boundaries of the "text" after you open DWG exported from Illustrator in AutoCAD, set lineweight of the objects (hatches) to 0 (zero), then print to PDF with "AutoCAD PDF (High QualityPrint).pc3 printer.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
