1237 Vistas, 10 Respuestas
Can't Join and/or Union Regions
I attempting to make a 3.47 by 3.80 by 1.98 speaker. I'm currently working on the outer edge of it, but I've run into a problem: I can't seem to make 2 unions join. (I'm trying to join the perimeter and the bottom.) I used the 'join' tool, didn't work, tried the 'union'  tool, didn't work, and didn't know what else to do. Please help me :cara_con_una_leve_sonrisa:
Etiquetas (2)
Etiquetas (3)
en respuesta a: Anonymous
If it'll help and if needed, I'll add a screenshot of  what I'm trying to join
pendean
"didn't work" means nothing to anyone over here, expand the commandline to 3-5-9 lines tall, try both again, and see what AutoCAD is actually telling you is the problem. That will make it easier to fix.
If you are still confused, then share your actual DWG file please.
It says "At least 2 solids, surfaces, or coplanar regions must be selected."
Also @pendean, I have no clue how to share .dwgs
Etiquetas (1)
pendean
>>>...I have no clue how to share .dwgs...<<<
Come to the website where you posted (here is the link https://forums.autodesk.com/t5/autocad-forum/can-t-join-and-or-union-regions/m-p/10353856#M1053531 ), click on REPLY button, file attachments are below the text box.
Or use your own OneDrive Account (free for every Windows user on the planet) or your DropBox account if you have and prefer to use it, to share files.
TIA
I am not a Windows User, I am a Mac user...but okay
Ok I think I did it
en respuesta a: pendean
I messed around with some stuff, pressed random buttons, and it appeared to of fixed it...
pendean
And your post is in the correct forum for MAC users to boot: remember to always post here moving forward.
Ok thanks I will
