rscarroll
en respuesta a: maxim_k
Thanks for your reply.
My question is about step #2 in the linked instructions:
> Navigate to the folder /Library/Preferences/Flexnet Publisher/FLEXnet and delete the files prefixed with adskflex.
The only Flexnet Publisher folder I can find (either visible or not) is in /Library/Application Support, and it does not contain any files named with the prefix mentioned.
The older instructions on resolving this kind of disk migration issue involved renaming the FLEXnet folder before going through the uninstall/reinstall process. Then moving back any files from the renamed folder after completing the install.
I’m trying to find out if this should be the same folder, but it is now in a different location.
rob
