- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi Drew,
Actually BLIPMODE is still there in AutoCAD LT for Mac, even in 2022 version. And you can enable it.
1/ Quit AutoCAD LT
2/ Go to ~/Library/Application Support/Autodesk/AutoCAD LT 2022 Standalone/R24.1/local folder and find HKCU_V1.plist file in it. Note - it is Library folder inside your Home folder, not in the root folder of your Mac . If you have 2021 version, then replace 2022 with 2021 in the path above.
3/ Open HKCU_V1.plist in plain text editor and use Find function to find BLIPMODE:
on the next line replace 0 with 1Ж
4/ Save HKCU_V1.plist and close it.
5/ Launch AutoCAD LT and test "blips", they should be there.
6/ To revert back - edit HKCU_V1.plist again and replace 1 with 0.
>>>>why are the icons so small?
Do you mean icons on the Tool Sets palette?
Yes, most of them are really small. And there is no official way to make them bigger. Look >>>here<<<
>>>>>"measure" no longer seems to "measure" a distance
Not sure what do you mean?
Maxim Kanaev
Architect
MARSS
