maxim_k
en respuesta a: Chris-Steelex
Hi @Chris-Steelex ,
At first try to install AutoCAD LT for Mac 2022.1 Update, which was released today. Use "Check for Updates" from menu AutoCAD.
If this will not fix the problem you may try to Clean Uninstall AutoCAD LT for Mac as described here:
https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/sfdcarticles/sfdcarticles/...
and here:
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Clean-uninstall-of-Autod...
Then install AutoCAD again and apply 2022.1 Update.
Just in case - please specify macOS version installed on your Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
