- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello everyone.
So since yesterday I have this problem with my AutoCAD Drawing.
All of a sudden the transparency of the layers went to 0% transparance and I could only see black and while colours on my working drawing. So I fixed the transparency issue by turning on the transparency button on, but my drawing is still black and white, and it is very annoying, as I can't work on it like that.
Also, when I plot it, some ( only some) of the line-weight is not printing to the correct size. I checked on my plot settings, layer settings, and everything seems to be correct.
Please help. Photos attached.
Thank you!!
Best
Vanesa
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Welcome to Autodesk Forums!
Hi Vanessa,
Please verify current Page Setup settings - use menu File->Page Setup Manager to edit current Page setup:
If "Display Plot Styles" option is enabled - uncheck it:
If you are sure about lineweight settings for Layers and lineweight settings in Plot Style table file, check if the objects with different lineweights have lineweight assigned individually: select object and look at the Properties Palette (Lineweight property), it should be "ByLayer" in order to print correctly, according Layer/Plot style table settings.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hello @maxim_k
My colours are back !!! Aren't you a star. Thank you so much.
About the lines... I am absolutely sure all the settings are set up correctly. Weird it does it only on one section, but I will probably reset it or redraw it as I can't see what might be the problem. I thought of double lines - not the case, I have only one line there.
Thank you for your time and help. Much appreciated.
Best Wishes
Vanesa
