329 Vistas, 2 Respuestas
Screen has been shrunken down to a rectangle strip area
Hello. How can I get my screen back to normal?
Etiquetas (4)
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Heidi,
If you are sure that the version of AutoCAD you are using is compatible with macOS on your Mac, then you can try to Reset AutoCAD - use menu AutoCAD -> Reset AutoCAD.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
I resorted to exiting the program entirely to correct the issue. It hasn't happened since, but if it does, I will try your suggestion.
