maxim_k
en respuesta a: Anonymous
Hi Chris,
1/ The layer with geometry - Vehicle - inside viewport is marked as "Not printable" on Layers palette. This is how it looks in Model space:
You have to turn on Print property for this layer.
2/ In Layout you have the following Page setup:
You selected "Extents" for "What to print" option.
But look at your Layout after using ZOOM -> Extents command:
 Looks like you have extra objects in all Layouts, so when AutoCAD saves to PDF to A4 sheet at 1:1 scale, the entire contents of the Layout simply doesn't fit on A4 sheet.
So you have erase extra objects from all Layouts or reconfigure Page setup - What to print - to "Window".
Or even better - to "Layout", but in this case, you will also need to move the contents of the Layout to new place.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
