- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
A few weeks ago, out of nowhere my AutoCAD LT just started running very slow. Every time I pull a dimension line the rainbow wheel spins for 30 seconds. Not Good... It happened instantly one day. I'm running on a iMac pro which has great processing and a high-performance upgraded video card so I don't think my computer is the issue... Any ideas on what is going on? Thx!
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Your LT year version is...?
Your MacOS version is...?
Is the problem in ALL files, or just this one?
Is the problem in all command, or just when dimensioning?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
AutoCAD LT 2021
MacOS 11.2.3
All Files
Not all commands but any that involve any calculating like Dimensioning
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous ,
I think you should try to clear all blocks from Recent Blocks tab of Blocks palette: right-click on empty space in that tab and select "Clear all" from context menu.
To stop population of Recent blocks tab with recently inserted blocks set System variable BLOCKMRULIST=0 (zero).
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@Anonymous
@Anonymous wrote:
How do I get to "System Variable BLOCKMRULIST"?
At the Command Window type BLOCKMRULIST and hit Return, then type 0 and hit return again:
Command: BLOCKMRULIST
Enter new value for BLOCKMRULIST <50>: 0
Command:
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Your previous directions regarding clearing the blocks helped a lot on the files I was work on before but I just opened another file and it's running quite glitchy again. Pulling dimension lines is not an issue anymore but the curser as I move and select items is rather glitchy and jumping around. Any suggestions here? Thx again. Neiel
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@Anonymous
Verify if you have SNAP turned ON - F9 key toggles it.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Yeah, I checked that. The grid snap is not on but it's jumping around similar to as if it was...
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
you don't use external display with low refresh rate, you can try to Reset
AutoCAD.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
archive with custom settings and it is possible to restore them if
resetting won't help.
Maxim Kanaev
Architect
MARSS
