471 Vistas, 1 Respuesta
AutoCAD 2020 LT for Mac - Object leaves traces behind after editing
Hi, I'm having an annoying issue with the AutoCAD Lt 2020 version on my Mac. Whenever I move, edit etc an object, there's a trace left behind that doesn't go away unless I pan or zoom. I'm using it on a MacBook Pro 2019 with updated specs. My old MacBook Pro could run the full AutoCAD version without any issues so I'm struggling to understand what the problem is.
I would really appreciate some help. I've attached a screenshot of what's happening. I dragged down on the middle grip and the old shape stayed behind.
Also if anyone has any ideas on why I can't click and drag an object that would be amazing. At the minute I have to right click - move to move the object which is quite cumbersome.
Thank you
Etiquetas (1)
maxim_k
en respuesta a: Anonymous
Hi Amy,
Is it 16" model?
If yes, you may try to switch from "Metal" Graphic Engine to "Open GL Core Profile" on General tab of AutoCAD Preferences.
Yes, this feature is not available in AutoCAD for Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
