joshualancefieldLFR68
318 Vistas, 1 Respuesta
AutoCad LT For Mac - autosave feature not working
Hello guys,
I am using AutoCad LT For Mac. The autosave feature is not working (have lost a lot of work as a result recently).
I am unable to locate any temp files on my system.
The drawingrecovery feature does not display any of my autosaves (I have autosave set to every 5 minutes).
When I try to find the location of the files through finder I am unable to find the Autodesk folder within the Documents folder.
I have tried to redirect the autosaves to a new folder on my system and there are still no autosave files appearing.
I should also point out that I am using i-cloud to store files. Perhaps this is a contributing factor to the issue.
Any help would be hugely appreciated!
cheers :cara_con_una_leve_sonrisa:
maxim_k
en respuesta a: joshualancefieldLFR68
Welcome to Autodesk Forums!
Hi @joshualancefieldLFR68
Autosave works on my side without problems with the default Autosave folder: ~/Documents/Autodesk/Autosave
Quite possibly.
Have you tried to redirect Autosave to the folder without iCloud sync enabled?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
