- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi Mario,
I received your drawing.
I changed color property for all objects in your drawing to “BYLAYER"
I used CHPROP command for this:
https://help.autodesk.com/view/ACDMAC/2016/ENU/?guid=GUID-05074362-FC4B-4582-A7A4-B3F6170BB4A7
Command: CHPROP<- Hit Return here
Select objects: Specify opposite corner: 77884 found
Select objects:<- Hit Return here
Enter property to change [Color/LAyer/LType/ltScale/LWeight/Thickness/TRansparency/Material/Annotative]:C <-Type C and hit Return here
New color [Truecolor/COlorbook] <varies>:BYLAYER <- Type BYLAYER and hit Return here
Enter property to change [Color/LAyer/LType/ltScale/LWeight/Thickness/TRansparency/Material/Annotative]: <- Hit Return here
Now all colours in the drawing will have “BYLAYER” color property.
Is that what you need?
Maxim Kanaev
Architect
MARSS
