- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Distorted 3D (ORTHO) view when plotting to PDF
... and possibly to printer, but unable to test.
Look closely at the (longer) pipe runs. The edges are intermittent!
The object in question is a 3D solid. As may be seen in the screenshot, the pipe looks fine in pspace.
(I've already checked: this is not a discontinuous linetype set to a bizarrely large scale. Also played with various plot styles & settings).
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hm, yes.
I suppose, in my hurry to post, I did not consider that this was a thing Mac would do that Windows could not.
Should I just copy-and-paste it there? —or may we move it?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The result that you get in PDF is expected as you use in the viewport Visual style other then 2D Wireframe. In this case AutoCAD export viewport contents to PDF as raster image.
The same result you will get in AutoCAD for Windows.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You may try to increase Raster image resolution in AutoCAD PDF printer:
(see attached)
it should be better, but the result still will not be ideal.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you!
Upping both to 4800 pixels must have done something, because now it takes a full 20 seconds to generate the PDF preview. The edges in question, however, are still missing.
Maybe I am going about this wrong. Once I have created a model which I am happy with, and want to share a particular with a client, what is the best way to export? Take a screenshot? Invite them over for tea?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
As I wrote before, "the result still will not be ideal". And it is "as designed".
If you need shaded (rendered) high quality view, you may also try to create hi-res rendering here:
https://gallery.autodesk.com/a360rendering
Maxim Kanaev
Architect
MARSS
