351 Vistas, 2 Respuestas
problem with typing line length
 I am having trouble with the length of the line (the same happens when I try to type the length of a radius in a circle and so on).  I tried looking at the definitions of the units and dimensions, but they are all according to the recommendations I found in the forum. After typing the length of the line in the command row nothing happens. I tried not specifying a unit of length and it draws the line just fine. But for some reason, it won't complete the line if I specify the length of the line (for example, typing in the command line: 18 and then enter, but nothing happens. Thank you in advance.
