maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Vedran,
Yes, DATAEXTRACTION command is not available on Mac.
But you can, for example, use FIELDs and AutoCAD table to extract area of hatches:
1/ Create simple table in the drawing and use one of its column to collect information about area of hatches
2/ Activate table cell, use Table Visor to insert FIELD in it - in Insert Field window select Objects -> Object -> pick one of the hatches as object type, adjust Area property format, pick on Choose
3/ Repeat step #2 to extract the hatch areas you need
4/ Now you have table with areas of all hatches
5/ Use TABLEEXPORT command to export the table to CSV file
6/ Open resulting CSV file in Numbers or other spreadsheet application of your choice.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
