- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Dear all,
I am having an issue regarding the extraction of data from drawing. Shapes are defined as polylines, or could be defined as block.
What I want is to export the area of the red shapes.
Extracting through the attribute data (-attext) or similar function did not work.
Similar extraction was successfully obtained from DATAEXTRACTION command which is not the option in the AutoCAD version for MacOS.
With kind regards
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Welcome to Autodesk Forums!
Hi Vedran,
Yes, DATAEXTRACTION command is not available on Mac.
But you can, for example, use FIELDs and AutoCAD table to extract area of hatches:
1/ Create simple table in the drawing and use one of its column to collect information about area of hatches
2/ Activate table cell, use Table Visor to insert FIELD in it - in Insert Field window select Objects -> Object -> pick one of the hatches as object type, adjust Area property format, pick on Choose
3/ Repeat step #2 to extract the hatch areas you need
4/ Now you have table with areas of all hatches
5/ Use TABLEEXPORT command to export the table to CSV file
6/ Open resulting CSV file in Numbers or other spreadsheet application of your choice.
Maxim Kanaev
Architect
MARSS
