maxim_k
en respuesta a: robbruce
Welcome to Autodesk Forums!
Hi Robert,
I think you you are facing a known issue with printing PDF files created with the built-in AutoCAD PDF printer - AutoCAD to PDF (*).pc3 or DWG to PDF.pc3.
The problem is in Preview app, and I believe you are trying to print from Preview app. For some reason Preview app prints raster PNG images which are created in PDF output from solid fills with transparency applied.
There are two workarounds:
- If you want to use Preview app for printing - convert PDF files in Preview app to raster images before printing (use menu File with Shift key -> Save As to save PDF to JPG image).
or
- use Acrobat Reader to print such PDF files, they will print correctly without any conversions.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
