maxim_k
en respuesta a: ksporry
Hi Kryn,
In AutoCAD for Mac you can change this option by changing OSNAPZ System Variable. The default value is 0 (zero), if you want substitute the Z-value of the specified point with the current elevation - set it to 1.
At the command prompt:
Command: OSNAPZ
Enter new value for OSNAPZ <0>: 1
Command:
Or with this AutoLISP statement:
(setvar "osnapz" 1)
It is not saved either in the AutoCAD settings or in the drawing, so you need to set it every time when you open a drawing.
If you want to set it to 1 permanently, look for the solution here:
https://forums.autodesk.com/t5/autocad-forum/replace-z-value-with-current-elevation-not-staying-sele...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
