maxim_k
en respuesta a: jvgerwen-PlantLab
Hi @jvgerwen-PlantLab
1/
>>>>>In any AutoCAD version, you will get an error on this Data link after you save it!
That is because you used incorrect AutoLISP statement to remove Data Link.
It should be:
(dictremove (namedobjdict) "ACAD_DATALINK")
but not " [color = # ff0000] (dictremove (namedobjdict) "ACAD_DATALINK") [/ color]"
2/
>>>>>So if you have a solution how to make a (Dynamic) block of, for example, a sewer pipe and this data (about the entire drawing) should be placed in a Google sheet I like to hear it.
At first I have to mention that in order to be able to update Excel document from AutoCAD, you need to have Excel installed on your Windows machine, because you need to use Data Link feature.
At the same time it is possible to create new table in AutoCAD each time you change Dynamic blocks parameters (tube length) and then export this AutoCAD table to spreadsheet.
Look at these articles:
- the first one uses Data link feature:
https://thecadgeek.com/blog/linking-excel-and-autocad-with-data-links/
- the second one uses Data extraction feature:
https://autodesk.blogs.com/between_the_lines/2010/03/autocad-tip---reference-a-block-count-in-a-fiel...
You may also ask your question about linking Dynamic blocks information with external spreadsheet on AutoCAD Forum.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
