jvgerwen-PlantLab
en respuesta a: maxim_k
Hello Maxim Kanaev,
Thanks for your quick response, i'm happy with it :cara_guiñando_un_ojo:.
I tried your proposal:
1) I make an Excel file from my Sheet data.
I can insert this Data sheet via DATALINK into AutoCAD 2021 for MAC. So that works without AutoCAD nagging you to install Microsoft Excel.
I save the drawing and open it again with AutoCAD WINDOWS.
(If you want to remove the datalink within AutoCAD WINDOWS, that will not work!)
Also not working with the option:
     A) rename or remove the linked .dxe files
     B) copy / paste this:
     [color = # ff0000] (dictremove (namedobjdict) "ACAD_DATALINK") [/ color]
     in the commandline, ENTER
     C) save and close the drawing, reload drawing
This has to go through the AutoCAD MAC version because you can simply remove it there.
In any AutoCAD version, you will get an error on this Data link after you save it!
Then I am faced with the fact that the data in the sheet is displayed too small.
If you select the sheet table, you cannot edit any text, if you select a cell in this table, you may edit the text in size, but this is not immediately possible for all data in it.
Anyone have a solution for this?
2) I can use both AutoCAD 2021 versions, both the WINDOWS and MAC version.
So if you have a solution how to
 make a (Dynamic) block of, for example, a sewer pipe and this data (about the entire drawing) should be placed in a Google sheet I like to hear it.
So if I draw 4 tubes of 6 meters with a certain diameter, they have to come back in the sheet. However, if I stretch a block to only 4 meters, this must also be indicated and adjusted in the sheet file.
Thanks in advance.
