cadffm
en respuesta a: earthsquare
Hi @earthsquare
i read in older post from you:
"I use AutoCAD LT 2021 for Mac."
If that is the case, you post in the wrong forum for two reasons:
1. This is the AutoCAD board, not AutoCAD for MAC (different programs)
2. This is the AutoCAD board (not AutoCAD LT)
StripMText is not available for AutoCAD LT for MAC
and you have only two ways as solutions:
1. Use another Program than AutoCAD LT-Version, so you can use StripMText (or similar)
 or
2. Learn more about DXF structure and edit your drawing files in ascii DXF files, directly in TextEditor.
It is always a good idea to indicate which software (name and version) it is about.
Sebastian
