10-14-2020
04:56 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-14-2020
04:56 PM
Thanks so much for your message. I thought I had set up correctly to print 24x36, that's definitely the issue. I also don't know if the ctb may be a part of the issue because my lines arent dark enough...
I fixed it to reflect 1:1, thank you for the note. I will also check the "fit" box on the PDF. I will reply back if this does not fix the issue, thank you!
