666 Vistas, 5 Respuestas
Run layer state in active viewport, turning off paperspace objects
Need some help. We have a drawing named "floor plan" xrefed and located in model space of our drawing "sheets" file. The "floor plan" drawing contains its own set of layer states - for floor plan, ceiling plan, etc. I have a sheet setup in the "sheets" file with a "titleblock" xrefed into paperspace and a viewport for the "floor plan" file. When I activate the viewport and run the layer state for the xrefed "floor plan" then the "titleblock" in paperspace turns off. Is there a way to run a layer state in a viewport and not affect paperspace objects?
Unfortunately, I cannot edit the "floor plan" layer states in the "sheets" file because the layer state editor will not allow you to edit layer states of an exerted drawing. Thanks.
Etiquetas (2)
